starting issues
SCOTT BASQUE
I have a 1972 chevy blazer with a crate 350. It is a project car. I am learning as I go. I am having starting issues. I have changed the starter, alternator and battery. I can successfully start it by using jumper cables but it will not start on its own. What am I missing to diagnose and fix the problem. Any help will be appriciated.
Thanks
Sep 30, 2007 at 8:09 AM
  • 75,988 POSTS
Load test the battery if it can handle 9.6 volts by cranking it over for 10secs using the starter as a loading device your okay, if not replace the battery-battery checks out
Now run direct power to the coil positive terminal from the battery positive terminal if it fires up-test the igniton switch ignition circuit its coming from there. Then comeback
Battery cables from and to are they cleaned and tight?
Sep 30, 2007 at 8:26 AM
