1988 Chevrolet Blazer Speedo Failure
BIOBEAR
I was on my way to the Mojave desert this weekend and well about 95 miles in my speedo stops working which in turn stopped the trip/total odo.
I imagine this fix is something like a loose screw or spool so shouldn't be that tough.
Question is:
Is it just a screw? If so how do I get to it?
-Side note-
It is really interesting driving a car through the desert plus the 3 hour drive home without a working speedo and a check engine light glaring at you all the while.
May 13, 2007 at 12:39 PM
  • 75,988 POSTS
[quote:4fe23f3bf3="biobear"]I was on my way to the Mojave desert this weekend and well about 95 miles in my speedo stops working which in turn stopped the trip/total odo.
Question is:
-Side note-
It is really interesting driving a car through the desert plus the 3 hour drive home without a working speedo and a check engine light glaring at you all the while.[/quote:4fe23f3bf3]
Try checking the vehicle speed sensor
May 13, 2007 at 8:16 PM
Suggested Repair
Check the vehicle speed sensor, which can stop both the speedometer and the trip/total odometer.
Conversation Summary
The owner of a 1988 Chevrolet Blazer reported that the speedometer stopped working about 95 miles into a trip, which also stopped the trip and total odometer. A check engine light was also on. The owner suspected a loose screw or spool. The expert recommended checking the vehicle speed sensor.
