S-10 4x4 Clanking while making left hand turns
OMGLOLETCETC
I have a 1993 4x4 S10 Blazer. It has 125000 miles on it. It runs fine, strong engine.
The only problem I have with it is every time I make a left hand turn I get a very loud "clanking" noise. It never happens when I make right had turns, only left. It also happens when I hit ditches on the left side as well
I was told it may need a new trans-axel.
The noise sounds like it is coming from the front driver side wheel.
I have no clue what it could be...any help???
May 19, 2007 at 3:56 PM
MIKE H R
  • 3,094 POSTS
have the bearingas and cv joint checked on both the left side and right, i have seen a noise in the left front being caused by a bearing in the right side.
May 20, 2007 at 3:44 AM
TENMAN
Ball Joints Check them carefully
Jun 5, 2007 at 3:33 PM
