Replacing Starter on 95
MDEMERS2006
  • 1995 CHEVROLET BLAZER
Hi All,
What is the easiest way to pull out that starter on a 95 4.3?
I tough of removing the Fly wheel cover but the last bolt is hard to access cause of the drive shaft. What If I remove the shaft then the Fly wheel cover, think it will be good then to remove that starter?
And why in God's name did they decide to make it so darn hard! :)
Thanks in advance,
Martin.
Sunday, February 4th, 2007 AT 3:39 PM
JEFTFIELDS
  • 74 POSTS
Im not sure why they have to make things so hard, but yes you will have to pull drive shaft and flywheel cover to at least make it easyer to replace the starter.
Sunday, February 4th, 2007 AT 3:46 PM
MDEMERS2006
Alright THX!I'm just glad that I did not get as an answer to Lift the motor ;)
Sunday, February 4th, 2007 AT 5:46 PM
