2002 Chevy Blazer Catalytic Converter
SERCHING4SOMETHING
If you replace the Catalytic Converter with a straight pipe on a 2002 Chevy Blazer 4.3 with 112000 miles, how do you stop it from throwing the Check Engine light without affecting other check engine signals?
Sep 25, 2007 at 7:29 AM
DENNYP
  • 1,824 POSTS
You cant get the check engine light to go out without the catalytic converter unless you have a hackbox of some kind.
This video will show you how to replace the Y pipe with cats on a similar vehicle.
https://youtu.be/CORe9JyrexI
Sep 28, 2007 at 12:08 PM
JAULT01
  • 51 POSTS
It's illegal... besides, it will throw codes because the back O2 sensor checks emissions and adjusts fuel etc from that data.
Nov 21, 2010 at 9:08 PM
EMACK88
It seems the converter has no bolts to remove it what do I do
Apr 13, 2019 at 11:26 AM (Merged)
  • 31,937 POSTS
If it is not a bolt up type, it will have to be cut out and a new cat welded in place, if you do not have the equipment this is a job for a mechanic or an exhaust fitter, the labour charge should be about 1/2 hr max.
KABBOTT1886
was just told that we need a catalytic converter. Our blazer has two of them and was also told that we can remove the one in the front part of the car and we won't have a problem.
Is it ok to remove the converter and not cause a problem with the car?
It won't do any damage to run without it will it?
RHALL77
  • 3,361 POSTS
I would not suggest permently removing cat converters. if they need to be replaced, i would suggest replacing them
DUCK
1997 chevy s10 blazer code p0420 def.catayst below threshold bank 1. What does this mean?
  • 110,251 POSTS
The catalytic converter isn't functioning within the specifications set by the manufacturer. It could be a vacuum leak, bad O2 sensor, or a bad converter.
CHRIS DIVITO REBECCA DHALIWAL
Check this out..........
https://www.youtube.com/watch?v=19CWNNBCv-Q
Aug 14, 2023 at 12:36 AM
Suggested Repair
Do not permanently remove the catalytic converters. Replace failed converters; if a unit is not bolted in, have it cut out and a new catalytic converter welded in by a mechanic or exhaust shop. A P0420 code means catalyst efficiency is below threshold and may be caused by a bad converter, oxygen sensor, or vacuum leak. Do not use devices intended to hide the check engine light.
Conversation Summary
The owner of a 2002 Chevrolet Blazer 4.3 asked how to remove the catalytic converter, install a straight pipe, and prevent a check engine light without affecting other codes. Experts said the rear oxygen sensor monitors emissions, so the light cannot be cleared without the converter, and advised against permanent removal. They recommended replacing failed converters, cutting and welding a new unit if it is not bolted. A separate 1997 S10 Blazer P0420 discussion indicated catalyst efficiency below threshold, possibly from a bad converter, oxygen sensor, or vacuum leak.
