Remove Catalytic Converter
CHEVROLET BLAZER
SERCHING4SOMETHING
If you replace the Catalytic Converter with a straight pipe on a 2002 Chevy Blazer 4.3 with 112000 miles, how do you stop it from throwing the Check Engine light without affecting other check engine signals?
Sep 25, 2007 at 7:29 AM
DENNYP
  • 1,824 POSTS
You cant get the check engine light to go out without the catalytic converter unless you have a hackbox of some kind.
This video will show you how to replace the Y pipe with cats on a similar vehicle.
https://youtu.be/CORe9JyrexI
Sep 28, 2007 at 12:08 PM
JAULT01
  • 51 POSTS
It's illegal... besides, it will throw codes because the back O2 sensor checks emissions and adjusts fuel etc from that data.
Nov 21, 2010 at 9:08 PM
EMACK88
It seems the converter has no bolts to remove it what do I do
Apr 13, 2019 at 11:26 AM (Merged)
  • 31,937 POSTS
If it is not a bolt up type, it will have to be cut out and a new cat welded in place, if you do not have the equipment this is a job for a mechanic or an exhaust fitter, the labour charge should be about 1/2 hr max.
KABBOTT1886
was just told that we need a catalytic converter. Our blazer has two of them and was also told that we can remove the one in the front part of the car and we won't have a problem.
Is it ok to remove the converter and not cause a problem with the car?
It won't do any damage to run without it will it?
RHALL77
  • 3,361 POSTS
I would not suggest permently removing cat converters. if they need to be replaced, i would suggest replacing them
DUCK
1997 chevy s10 blazer code p0420 def.catayst below threshold bank 1. What does this mean?
  • 110,244 POSTS
The catalytic converter isn't functioning within the specifications set by the manufacturer. It could be a vacuum leak, bad O2 sensor, or a bad converter.
CHRIS DIVITO REBECCA DHALIWAL
Check this out..........
https://www.youtube.com/watch?v=19CWNNBCv-Q
Aug 14, 2023 at 12:36 AM
