Chevrolet Blazer
SKIPPYOJEN
  • 5 POSTS
I have a 95chevy s10 blazer with a 4.3 vortec and it runs fine when i want to go to the store. after all i replaced the o2 sensor codep0131 and replaced the fuel pump. what is happining is that on my return giving it gas it hesitates and studders, but constant pressure on the gas pedal seems to make it run fine, it shifts fine and everything and i had plugs, wires and a tranny fluil and filter change so what could be the problem
Feb 26, 2007 at 5:26 AM
CHEVY22
  • 1,375 POSTS
first i would like to ask which 02 did you replace ??
second were gm plugs used ???
is the engine light on now??
let me know
jim
Feb 26, 2007 at 7:24 AM
SKIPPYOJEN
  • 5 POSTS
it was bank one sensor one thats what the code picks up p0131
no the plugs are not gm but those have been checked out to the right gap and all.
Feb 26, 2007 at 2:24 PM
CHEVY22
  • 1,375 POSTS
i just wanted to be sure you replaced the upper 02 on the drivers side , and the plugs some work and some foul out gm plugs are the best imo i have never had a problem with them like i do with aftermarket
and you didnt say if the light was on again
thanks
jim
Feb 26, 2007 at 10:41 PM
SKIPPYOJEN
  • 5 POSTS
at the time the service engine light was on and the o2 sensor is not on the drivers side it is just after the t on the pipe after the manafolds on the passenger side. now i dont know cuz i went all over the place today and its running fine and the light is out.
Feb 28, 2007 at 9:05 AM
CHEVY22
  • 1,375 POSTS
well just some fyi on 6cyl engines the bank 1 sensor one is on the left manifold rather just below it.
good luck
jim
Feb 28, 2007 at 10:55 AM
