Having to Shift Manually with Automatic Transmission. Help!
JONFIT04
Well.. here is the deal. My mother is now a new owner of a 1998 Chevy Blazer LS 4x4 with 156k 4.3. The problem she is having is that, when driving. She has to shift through the gears manually on an Automatic Transmisson. When she puts the truck in (D) Drive. It goes nowhere. In order for it to go anywhere. She has to shift up through the gears from 1st-2nd-3rd and then Drive. What could be the problem? She bought the vehicle at a local auction and did not realize the problem until after paying for it and going out to take it home. On her way out the seller comes out and says he forgot to mention it on the auction block. Since she bought it as-is, she cant return it. So any help that you can provide would be great.
Jun 8, 2007 at 11:24 PM
TOYPAR
  • 12 POSTS
sounds like the valve assy needs to be pulled and cleaned. The transmission may have never been serviced i.e. oil and filter change. Try replacing the filter but while the pan is off pull the valve assy and clean it with parts cleaner and make sure all passages are clean and free of debris. Sound like a part of the belt got stuck in the valve assy.
Jun 26, 2007 at 2:03 AM
MIKEY0715
I have a 96 chevy s-10 blazer with 161,000 and resently had my transmission do the samething and it blew up and locked the torque convertor all at the same time. Please have it checked out before it does the same to you.
Aug 6, 2007 at 3:45 PM
