fuel consumption
CONFEDERATE
I have a 96 Blazer, acts as though it is flooding, I've changed injectors, fuel regulator, plugs, wires cap & rotor, MAP sensor, catalytic convertor, no help. Fuel consumption has gone from 20mpg to 10 mpg. I also had the PCM reprogrammed. It's as though the PCM is receiving info to send more gas. I also can only get 1 code 300 (random misfire) I need the solution, can you help?
Oct 1, 2007 at 10:04 AM
DENNYP
  • 1,824 POSTS
[quote:f2e090385a="confederate"]I have a 96 Blazer, acts as though it is flooding, I've changed injectors, fuel regulator, plugs, wires cap & rotor, MAP sensor, catalytic convertor, no help. Fuel consumption has gone from 20mpg to 10 mpg. I also had the PCM reprogrammed. It's as though the PCM is receiving info to send more gas. I also can only get 1 code 300 (random misfire) I need the solution, can you help?[/quote:f2e090385a]You might want to try a cylinder leak-down test.It will be more of a pinpoint test than running a compression check.
Oct 1, 2007 at 2:44 PM
