2000 Chevrolet Blazer Stalls in Drive
SKINNP
I have a 2000, 2WD, 4.3 Chevy Blazer with 95k on it that idles ok and can be driven in reverse ok, but stutters and stalls when in drive. Spark plugs, Crank sensor, PCV have been changed. Fuel pump is ok as well as IAC. Transmission fluid checked and visual of vacuum lines appear ok. ?
Hello, it ended up by being the crankshaft position sensor connector. Changed the connector and the sensor again and all is well. Thanks. :)
Aug 12, 2007 at 9:17 AM
2CARPRO JACK
  • 11,533 POSTS
Any codes? Could be a trans problem. Check the wiring harness for rub-through where it crosses from the engine to the PCM near the battery. The hose clamp on the heater hose can rub into the harness and cause all sorts of trouble.
Aug 15, 2007 at 9:18 AM
Suggested Repair
Replace the crankshaft position sensor connector and sensor if the engine stalls in Drive. Also scan for codes and inspect the engine-to-PCM harness near the battery for rub-through from the heater-hose clamp.
Conversation Summary
A 2000 Chevrolet Blazer idled and reversed normally but stuttered and stalled in Drive after plugs, the crank sensor, PCV, fuel pump, IAC, fluid, and vacuum lines were already checked. An expert suggested codes, a possible transmission issue, and harness rub-through near the battery. The owner later reported that replacing the crankshaft position sensor connector and sensor again fixed it.
