door locks
C LONG
On 1988 blazer s10. Drivers side door lock is broken, can it be replaced, by me, at home. Best place to order replacement?
May 27, 2007 at 2:46 AM
MIKE H R
  • 3,094 POSTS
you can replace it yourself or have someone do it, raise the window completly, remove the door trim panel, detach the lock cylinder linkage, slide the retainer forward, then the lock can ber removed from the outside. installation is reverse of removal.
May 27, 2007 at 4:28 AM
