there is one spark plug blocked by the steering column on the driver side of a chevy blazer 2000. I would like to know how to remove this one plug
May 29, 2007 at 3:09 AM
BRUCE HUNT
✓Experienced Mechanic
The trans lube would not cause the clutch to fail. The improper installation of the clutch sounds like the problem. When they did the new engine if they put in the clutch as a new unit I would demand satisfaction. Don't know the age of the clutch.
