I was driving at 60 mph and all of a sudden it just shut off. No warning, no sounds, no smells, just shut off as if I turned the key off.
I've replaced the ingnition coil, the ignition module, & the map sensor. I have spark at all plugs, and the fuel pressure is within specs at the test port. The motor cranks but won't fire. No codes are showing on the OBD II.
Nov 25, 2007 at 10:43 AM
