Chevy Blazer Fuel Pump
JWAXSOM
Most times after I have driven my Blazer, and I restart I drives sluggush for about 30 seconds, then drives normally. Yesterday after being parked for about 8 hours i attemped to start it and it turned over but appeared not to be getting any gas, I called a roadside assistance guy he banged on the fueltank while I attemped to start it and after a while it did start.
should I get my fuel pump replaced?
thanks,
john
Nov 29, 2006 at 12:13 AM
CMMOORE
  • 7 POSTS
first of all what year is it? Voretc blazers need exactly the right fuel pressure to start. especially when cold. I believe the spec is 63psi. I've had ones with 60 psi that would not start. Find the spec for your vehicle and check what the pressure is. Good Luck!
Nov 29, 2006 at 2:16 PM
ANTHONY_ROGERS2001
wal mart has a gum out feul system flush they do in the service area for 20.00 . try this. it worked for my 97 blazer
Nov 30, 2006 at 3:07 AM
