Breaking u-joint
DAN-MAN71
Is there anyway to repair a screwed up rear output yoke, the raduis for the cap bearing is flared out towards the center of the yoke causing the u-joint to wobble. Money is a little tight right now and I need a quick fix for little or no money. I've heard of people putting a nickle (5 cents) in the radius and forcing it down into the radius to support the u-joint. HELP I'm busting u-joints about every 5 days.
Nov 2, 2007 at 2:44 PM
RAYT333
  • 27 POSTS
You should be able to pick up a used yoke from a junkyard for a little more then what the u-joint costs.
Nov 2, 2007 at 4:34 PM
