Blazer S10 Problem
GETATME
I have an 88 Blazer S10 and it began to slow down gradually then died on me on the freeway. I disconnected the line from the tank to check the fuel pump and it spit gas out when I started the engine. I replaced the fuel filter in case it was clogged. It will start once and then die and not start again. What could be the problem? I also recently replaced the radiator because it was cracked and drying out very fast, but it started losing all the water again after about a month with the new radiator in. Any help is appreciated. Thanks.
Sid
Dec 9, 2006 at 11:10 AM
CANVIS69
  • 131 POSTS
Is the oil ok? How about the state of tune? Need more info
Dec 9, 2006 at 3:22 PM
GETATME
The oil pressure gauge has been wavering a bit since I changed the oil and put in a new radiator a few months ago. It was also refusing to move until I floored the pedal sometimes at stop lights. I recently changed the plugs, air filter and the wires. Right before it died it was jumping forward while I had the brake pressed and then it'd lose power. It was also leaking what looks like oil, but I checked the oil a few times and the level was the same.
Dec 9, 2006 at 4:08 PM
