abs light and brake light on at same time
MATTHEW8510
have 01 chevy blazer bought 2 months ago with 53000 miles. just recently the abs and brake light are on at same time they will go off for a while and go back on again could this be the wheel sensors or something else please help me
Mar 26, 2007 at 2:39 AM
XANDER2280
  • 6 POSTS
I recently had the same problem after getting new brakes done on my blazer. If you hook it up to a diagnostics machine, you'll probably get code 38: wheel speed signal malfunction. I was told it had something to do with an abs sensor, but they also said they were getting a code 38 as well. (les schwab)
May 5, 2007 at 3:57 PM
VAL-G
I was informed yesterday by the dealer that my electric brake control module was gone and needed to be replaced at the cost of $1000.00 which won't be happening anytime soon. I was also informed that eventually I was going to have to replace it.
I bought my blazer brand new, 2001 and currently has approximately 56,000 miles on it. :x
Jun 20, 2007 at 2:07 AM
2CARPRO JACK
  • 11,533 POSTS
A scan of the PCM in the ABS system will give you any codes the comp has
Jun 20, 2007 at 5:50 AM
