98 Blazer LS, miles: 133000, V6 4.3L
KEHSUNAH
Forgive me if this sounds ignorant: check engine light and cruise control light does not come on at all on startup on any other time. I thought check engine should come on when starting then go off if everything is okay. This doesn't happen. The creuise control works, but no light/indicator comes on while it is on. All other indicator lights seem to work. Gate Ajar lights correctly/appropriately. What can I check if anything to fix? Thanks for your help.
Aug 20, 2007 at 12:57 PM
  • 75,988 POSTS
[quote:4855fbcc44="kehsunah"]Forgive me if this sounds ignorant: check engine light and cruise control light does not come on at all on startup on any other time. I thought check engine should come on when starting then go off if everything is okay. This doesn't happen. The creuise control works, but no light/indicator comes on while it is on. All other indicator lights seem to work. Gate Ajar lights correctly/appropriately. What can I check if anything to fix? Thanks for your help.[/quote:4855fbcc44]
Could be both of the lamp are burned out or you have a ground problem. Does it starts up with no driveability problems?
Aug 20, 2007 at 4:32 PM
KEHSUNAH
Drives great. There's nothing that I can smell, see or hear of that's odd.
https://images.2carpros.com/forum/automotive_pictures/94269_new_car_016_1.jpg
Aug 20, 2007 at 11:44 PM
