SLID_N
How do I remove the rear axle C-clamp on a 97 blazer w/locking diff.
Nov 5, 2007 at 1:11 AM
CHEVY22
  • 1,375 POSTS
with the truck off the ground , remove the rear diff cover and drain , center the diff where you can see the c-clips , on the opposite side you will have to remove the center pin bolt , roll the diff back to where you can see the c clips , grab each wheel and pull inward with a small magnet or pick you will now be able to remove the clips
jim
Nov 5, 2007 at 4:16 AM
