i have a 93 blazer.. it seams to be shiftin from 1 st to 4th in a matter of seconds sucking the gas quick any help?
Oct 13, 2007 at 4:35 AM
✓Experienced Mechanic
Get these sensors check the CTS/TPS/VSS these guys tells the TCM/PCM the throttle and governor pressures which provides the shifting/lock-up of the tranny-computer don't get the right signal it will not shift/lock properly.
Way back during the plastic bag we use intake vacuum to provide shifting-now its all electronically controlled.
