2006 Chevy Blazer oil mixing
2,000 MILES • 6 CYL • AWD • AUTOMATIC
SAMMIDYSAM
I HAVE OIL MIXING INTO MY WATER BUT ALSO IN MY GAS! WHEN I TAKE OUT MY OIL STICK IT IS CLEAR!! THE MECHANIC I HAVE HAS NEVER DONE THIS B4 N I NEED AN EXPERT!!! THANKS FOR UR TIME!!!
Dec 30, 2008 at 7:21 PM
  • 110,248 POSTS
Hi:
Have a compression check done on the engine. My guess is there is a blown head gasket. Coolant, oil, fuel don't mix unless a gasket is bad (intake or head) or you have a cracked or warped head.
Jan 3, 2009 at 10:42 AM
