2004 Chevy Blazer ses light
76,000 MILES • 6 CYL • 4WD • AUTOMATIC
KTM513
my blazer shows codespo135 and po155,, I replaced both sensers, cleared codes all ok till the next morn,,again clearsd codes all ok ,,light comes on only when sitting overnight
Dec 16, 2009 at 1:50 AM
SWILLIAMS
  • 597 POSTS
Sounds like the power circuit for the O2 heaters has a problem. NOT the sensors themselves. Both of the front sensors get power from the same place, the 20 amp fuse in the under hood fuse box. See if the fuse is OK. If the fuse is OK then pull the connector from either of the sensors and check the pink wire for voltage. If you have a good fuse but no voltage at the sensor check the wiring for damage.
The other side of the heater gets grounded through the ECM.
Dec 17, 2009 at 4:26 PM
KTM513
I have power to the pink wire,,after taking it to a pro ,,he said to clear the code with a solus?I will let you know if it worked thanks
Jan 1, 2010 at 4:04 AM
