Door WIndow?
61,000 MILES • 6 CYL • 4WD • AUTOMATIC
BOBDOSS
How do I get the door panel off to change the window regulator? Are there special tools? I am mechanically inclined, an electrician and I think I can do this repair. Thanks Bob Doss
Jul 4, 2009 at 1:05 AM
BMRFIXIT
  • 19,053 POSTS
Tools Required J 38778 Trim Pad and Garnish Clip Remover Removal Procedure Remove the inside door handle bezel.
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_198.jpg
Remove the power accessory switch mounting panel, if equipped with power accessories. Remove the trim panel armrest screws. Use the J 38778 in order to release the door trim panel retainers. Remove the door trim panel from the door.
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_416.jpg
Jul 4, 2009 at 11:01 PM
JACOB_NELSON
How do you replace the passenger side window of a 2000 Chevrolet Blazer?
Aug 12, 2020 at 10:40 AM (Merged)
GMTECH
  • 537 POSTS
FIrst you have to pull the door panel off and clean out any broken glass. The you will have to take all the rivets out of the regulator in order to be able to maneuver the regulator to line up with channel of the glass. THis video shows the job being done on a similar car, it shows the steps.
https://youtu.be/oNxstjcA25k
RHONDA LEEANN BLYTHE DUNHAM
i had driver door window replaced by a mobile repair foreigner. ever since the battery acts like its drained. could the power window have anything to do with my drained battery?
Good morning,
Maybe but needs to be confirmed.
What you need to do is to remove the negative battery cable and put a voltmeter in line. Red lead on the cable and black lead on the battery post. Set the meter to DC amps.
You should have no more than 50-75 milliamps. If you have more than that, remove the fuses one by one until the reading drops to within specs. Then let me know what fuse is the issue and I can get you the components it powers.
TRAINMASTER
Interior problem
1999 Chevy Blazer 6 cyl Four Wheel Drive Automatic
Recently my rear power window was smashed out. When I replace the glass, do I have to drill the factory rivets out of the motor bracket to replace the glass?
Aug 12, 2020 at 10:41 AM (Merged)
  • 110,248 POSTS
Hi:
If the motor was damaged, yes. Drill out the rivits and replace them with nuts and bolts. If it wasn't damaged, you should be able to replace the glass without removing it.
STANZI
driver side window does not go down. all other windows work.is there a motor for each window? what could be the cause of failure?
DOCFIXIT
  • 18,828 POSTS
Yes motor for each window it maybe motor or switch. Have you checked fuses?
BUDDYCRAIGG
  • 2,262 POSTS
yes, there is a motor for each window.
it could be the motor or the regulator
BURNFAN06
I HAVE A 99 CHEVY BLAZER. THE WINDOW MOTOR ON THE DRIVERS SIDE HAS GONE BAD. NOW NONE OF THE FOUR POWERS WINDOWS WILL ROLL DOWN. IVE REPLACED THE MASTER SWITCH ON THE DRIVERS SIDE AND NOTHING. IF YOU TRY TO GO TO EACH INDIVIDUAL DOOR AND TRY IT THEY STILL WONT WORK. ANY IDEAS??
CARADIODOC
  • 34,407 POSTS
Pull the boot back and check for broken or frayed wires between the driver's door hinges.
JDL
  • 16,098 POSTS
Is there a lock-out at the master switch? If the lock-out is set, the other window switches may not work? Also use a voltage tester at the power window circuit breaker, should be hot/voltage with key on.
When you try to operate window, is circuit breaker hot to the touch? If it trips, none of the windows will work.
BURNFAN06
ive had mechanics where i work look at it. the master switch on the drivers side has door locks and mirrors on it. those work fine. there is no power going to the window part of the switch.
JDL
  • 16,098 POSTS
You need to check the wiring circuits yourself. Caradiodoc is correct, sometimes those wires do break. Hinge side of door.
JACKFLUEGEL
2000 blazer driver window only works sometimes. is there a quick fix without replacing the motor? it still makes a sound like there is power going to the motor
FIXITMR
  • 9,989 POSTS
dont work at all or barely works(trys)?
JACKFLUEGEL
sometimes it works perfectly. other times it doesnt work at all.
FIXITMR
  • 9,989 POSTS
but it sounds like motor is running even though window does not move?
JDL
  • 16,098 POSTS
Is the power window circuit breaker getting hot, when the problem occurs, feel of it? If the circuit breaker trips, none of the windows will work, at that moment. Just a thought.
HANWAY_E
how to remove back quater glass from a four door s10 blazer 1995 ?
Aug 12, 2020 at 10:42 AM (Merged)
FIXITMR
  • 9,989 POSTS
did ya get er out?
HDHARDTAIL
  • 5 POSTS
How do you replace the quarter glass? I need to remove a good glass and install it in another vehicle. it is the rear glass in the rear quarter pannel, is is stationary and does not open.
HMAC300
  • 48,601 POSTS
take it to a auto glass shop, because teh urethane that you need to install it is way to exspensive as well as the activator to make it work right.
HDHARDTAIL
  • 5 POSTS
This was the wrong place to go for help, Im not going to load a junk car on a trailer and haul it 20 miles to a glass shop, just to have them remove the glass, I don't mind taking the one to them that runs, thats why I asked for help on removing it. Sure didn't take muck talent to come up with that answer, hell my wife could of come up with that.
HMAC300
  • 48,601 POSTS
the reason i say go to a glass shop is that usually when glass gets old it breaks when you try to remove it. You may bo to a junk yard and see if they have one already taken out for you. If you are bent on replacing ityourself then go ahead and get one from a junk yard, Make sure to do this outside as the chemicals that are required are not the best ones to be around. When you take out the old glass you'll need a heat gun to help you get through the old urethane as it gets very hard after time.
HDHARDTAIL
  • 5 POSTS
Wasn't too hard to do, took a while to carefully cut out the old glass, a tube of urethane cost $18.00, Window is also held in place with 8 clips so I didn't have to use tape to hold it in place till urethane dried. Think I'll do the windshield next, it has a small crack in it and I can get a new one for $68.00,
