2004 Chevy Blazer 4 hi won't engage
2004 CHEVROLET BLAZER
97,000 MILES • 6 CYL • 4WD • AUTOMATIC
DD1969
Was wondering if someone knew the location of or knows of diagram for the front axle vacuum actuator for a 2004 chevy blazer. Problem is that when I attempt to go into 4 hi the lights on my puch button control panel flashes then defaults back to 2hi. It has no problem going into 4 lo, just 4 hi, thanks.
Jun 20, 2008 at 6:30 AM
SWILLIAMS
  • 597 POSTS
Sounds like a faulty switch, TCCM or actuator on the transfer case.
The vacuum actuator is under the battery. However if it goes into 4lo the actuator is working.
Jun 25, 2008 at 4:30 PM
