2003 Chevy Blazer Won't Start
MDV2000
  • 2003 CHEVROLET BLAZER
  • 6 CYL
  • 14,700 MILES
I have a Blazer with the 4.3L engine that won't crank at times. I have had the fuel pump tester, the fuel pressure regulator replaced and dealer diagnostic test it and they find nothing. I also recently had fuel filter changed.
I cannot find what it wrong, and computer doesn't code anything - yet it at times won't crank. I let it set for a day, it crank fine every time for a few days to a week and then does it again!
It is driving me crazy - any ideas?
Thanks,
Mike
Wednesday, August 27th, 2008 AT 7:08 PM
KHOOPER
  • 22 POSTS
If you are experiencing that problem you mighy have a lack of fuel to the engine. In this case the engine will crank over and sound as if it wants to start. A quick test is to turn off all accessories, turn the key to on and listen for a low volume humming noise. This noise is the fuel pump. If there is no noise it is likely the engine is not getting fuel. A blown fuse, faulty relay, or bad fuel pump may be the cause.
Friday, January 29th, 2021 AT 11:22 AM
MDV2000
Yeah, the fuel pump is running and I've had it tested twice by dealer mechanic - they can't find anything and don't have a clue to why it won't crank. I've been slowy replacing cheapest parts with a hope to finding the culprit. I think it has to be electrical, but don't know where else to look. Every time the dealer puts it to their computer to diagnose it, they come back with nothing.
I have had a service light for an O2 sensor - but they said that wouldn't stop it from cranking.
Maybe I need to fix that and see if its masking something else.
Thanks.
