2003 Chevy Blazer Temp gauge
MICHAEL_MADDOX
Engine Cooling problem
2003 Chevy Blazer 6 cyl Two Wheel Drive Automatic
Please help diagnose the following problem:
My temp gauge and my oil gauge are not working properly. My terminology will be horrible so bare with me. My temp gauge will not stay at the half way point. it is suddenly sitting at the 3/4 point. I know it's not low on fluid because the over flow has antifreeze plus I've checked. My oil gauge goes from 1/4 point and bounces-never idle for any time.
*I live in Phoenix,AZ
I turned my air on two weeks ago and that is when I thought I blew my radiator. my temp gauge jumped and when I got home It appeared to be leaking. Not so! it wasn't antifreeze leaking! I bought Bar's Stop Leak and now my gauge sits @ 3/4. I have no explanation for the oil gauge. That has been going for a year now. My main concern is overheating.
Aug 15, 2010 at 12:42 PM
HMAC300
  • 48,601 POSTS
you may be not getting good power or grounds to the senders or the the senders are no good. The oil could be a bad oil filter as well and the coolant could also be a bad radiator. you need to have these checked.
Aug 17, 2010 at 5:37 AM
