2003 Chevy Blazer Stalls while driving
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROTTENBASTARD
My 2003 Blazer stalls while driving. This does not happen on cooler days, only when it is hot out. It does this primarily during city driving although it also has occured while highway driving.
Jun 22, 2009 at 7:25 AM
SWILLIAMS
  • 597 POSTS
Have seen the same problem on more than one. The cause was a bad fuel pressure regulator. You need to test the pressure output and see if it is holding residual pressure as it should. Also test the pressure and see if it is within the proper range.
Jun 24, 2009 at 4:15 PM
