2003 Chevy Blazer Possible transfer case fluid issue?
86,000 MILES • 6 CYL • 4WD • AUTOMATIC
ICEMAN468
The vehicle runs and drives ok normally in 2 wheel drive as long as I'm not making sharp turns.
But if I make a hard turn it requires a lot more rpm's from a stop before it engages the turn.
Also Backing up is a little jerky and again requires more engine rpms before it engages.
Transmission fluid levels are ok.
Seems as if it doesn't build up enough pressure unless I run the engine at higher rpms at turns or when backing up.
The problem is even worse in 4 wheel drive.
A friend advised it could be due to low transfer case fluid level so I am just checking around for a second opinion.
Jul 5, 2010 at 9:11 PM
HMAC300
  • 48,601 POSTS
sounds more like a trans problem, have a trans pro check this out.....
Jul 8, 2010 at 11:19 AM
