2003 Chevy Blazer Humming sound
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
EILEENR
My blazer is making a humming sound, seemingly from the right front wheel. If it was from a bad bearing, I am told the sound should change when turning the wheel, it should either stop or get worse. Turning the wheel has no effect on the sound. Any suggestions?
Sep 21, 2008 at 12:46 PM
RHALL77
  • 3,361 POSTS
it still might be a bearing. you need to jack it up and see if it is loose. It may also just be a cupped tire
Sep 22, 2008 at 9:15 AM
