2003 Chevy Blazer heater vacuum line problem
MPW995
Heater problem
2003 Chevy Blazer 6 cyl Four Wheel Drive Automatic
My Blazer's climate control is not working. I can hear a vacuum leak from behind the vent selector switch. I took the vacuum switch out and noticed it was covered with oil. With the car running and the vacuum lines off the switch it is a very quiet leak but when I plug it back into the switch, it gets a lot louder.
I only have air blowing from the dash vent. It will not switch over to floor or defrost.
Any suggestions???
Apr 17, 2009 at 12:18 PM
  • 110,246 POSTS
If the sound is louder when you attach the switch, it sounds like it needs replaced.
Apr 20, 2009 at 10:23 AM
