2003 Chevy Blazer fuel pump relay location
50,000 MILES • 6 CYL • 4WD • AUTOMATIC
MOODY69
my truck was running fuel pump was humming now no gas to the filter what are some of the things i can do before dropping the tank and replaicing the fuel pump where is the relay and fuses thanks . walking
May 1, 2010 at 4:53 AM
  • 75,988 POSTS
The fuel pump relay is in the underhood fuse block -check the fuel pressure with a gauge that's if you can hear the fuel pump come on.
May 1, 2010 at 8:05 AM
