2003 Chevy Blazer Four Wheel Drive Automatic 45000 miles
Where is the Coolant senser located. On my truck. And is there anything complicated about changing this senser. And how do I Turn off the Check Engine light.
Monday, December 17th, 2007 AT 7:18 PM
BLACKOP555
MECHANIC
Coolant temp sensor is located near upper radiator hose infront of throttle body, directly under it.
Theres nothign complicated about it at all
to reset the check engine light you just have to remove the - battery cable for 10minutes and it should reset.
