2003 Chevy Blazer blower switch
LKNOTT34
  • 6 POSTS
Air Conditioning problem
2003 Chevy Blazer 6 cyl Two Wheel Drive Automatic
The blower for my A/C is not working. Problem seems to be between the controls and the blower itself. I want to check the blower switch but wanted to know where to look for it before I just start pulling things apart...
Jun 6, 2010 at 3:17 AM
  • 75,988 POSTS
Try powering the blower motor from the battery and see what happens if it works check blower motor relay and resistor okay here test the blower switch
Jun 6, 2010 at 9:06 AM
LKNOTT34
  • 6 POSTS
Checked the motor and it is good. I have swapped relay and resistor. Where is the blower switch located?
Jun 6, 2010 at 9:27 AM
  • 75,988 POSTS
Disregard the blower switch check and test the blower motor speed controller behind right side of I/P on plenum
Jun 6, 2010 at 9:42 AM
LKNOTT34
  • 6 POSTS
I'm sorry, but you are dealing with an idiot. What is the I/P?
Jun 6, 2010 at 11:16 AM
  • 75,988 POSTS
Its the I/P ( Instrument Panel ) no problem
Jun 6, 2010 at 11:20 AM
LKNOTT34
  • 6 POSTS
Do I have the correct part??
https://images.2carpros.com/forum/automotive_pictures/359670_DSC03797_1.jpg
https://images.2carpros.com/forum/automotive_pictures/359670_DSC03799_1.jpg
Jun 6, 2010 at 11:38 AM
  • 75,988 POSTS
Look at the pic below-there's a connector-which is for the blower motor speed controller at no.12 verify the connector to the controller mating surface. If it matches you're on the right track.
https://images.2carpros.com/forum/automotive_pictures/12900_blower_control_module_1.jpg
Jun 6, 2010 at 11:58 AM
