2002 Chevy Blazer Will not change heat direction
87,500 MILES • 6 CYL • 4WD • AUTOMATIC
JLB71
When I use the heat it comes out of the dash vents and when i switch the controler it will not change to defrost or the floor it jst keeps blowing out the dash vents.
Jan 8, 2009 at 2:21 PM
BRIAN 1
  • 1,030 POSTS
try this:Some customers may comment that the HVAC mode switch may be inoperative or stuck in the vent mode. After some diagnosis, oil in the HVAC control head and/or vacuum lines may be found.
Cause
When the transmission or transfer case heat up, the oil may expand and find its way into the transfer case vacuum switch. This oil expulsion may cause the vacuum switch seal to fail and allow transfer case oil to be drawn into the HVAC vacuum lines.
Correction
Replace the transfer case vacuum switch. Refer to the Transfer Case Vacuum Switch Replacement procedure in the Transfer Case sub-section of the Service Manual. Also, replace all contaminated parts in the HVAC system.
post back with any other questions.
Jan 9, 2009 at 4:58 AM
