2002 Chevy Blazer rr wiper
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
BOOMER128
gate ajar light stays on and the rr wiper not working changed fuse no help
Oct 17, 2008 at 5:02 AM
SWILLIAMS
  • 597 POSTS
Sounds like the rear gate switch may have failed or disconnected. Either will cause your problem. The wiper is shut down if the gate ajar light comes on to prevent damage to the wiper. To get to the switch you have to pull the trim panel inside the lower rear hatch. You will find the switch attached to the side of the rear glass latch.
Oct 18, 2008 at 6:52 AM
