2002 Chevy Blazer rough idle, wants to stall when the engin
2002 CHEVROLET BLAZER
155,000 MILES • 6 CYL • 4WD • AUTOMATIC
JIMBO6395
When you first start the engine, the engine idles between 300-500 RPM and very rough. The engine wants to stall when you slow down at a stop sign, you need to keep your foot on the gas to keep it running. After the engine gets up to running temp, the idle speed is a steady 500 RPMs in gear and idles fine.
Aug 8, 2010 at 1:19 PM
Hi jimbo6395, Welcome to 2carpros and TY for the donation
Clean out the idle air control valve and the EGR valve, also test the throttle position sensor and the manifold absolute pressure sensor-also the mass airflow sensor with an approved electronic cleaner-let me know
Aug 8, 2010 at 6:00 PM
