When you first start the engine, the engine idles between 300-500 RPM and very rough. The engine wants to stall when you slow down at a stop sign, you need to keep your foot on the gas to keep it running. After the engine gets up to running temp, the idle speed is a steady 500 RPMs in gear and idles fine.
Aug 8, 2010 at 8:19 PM
