2002 Chevy Blazer REVVING LIKE SOUND
114,000 MILES • 4 CYL • AWD • AUTOMATIC
TA8184
REVVING LIKE SOUND WHILE DRIVING, NOISE WILL STOP WHEN FOOT IS OFF THE ACCELERATOR.
BREAK KICKS BACK ON FOOT MAKING SOME KIND OF SOUND.
Dec 10, 2008 at 12:48 AM
SWILLIAMS
  • 597 POSTS
The first sound could be almost anything from a vacuum leak on to a bad fan clutch. Does it do it all the time? Only when cold? Any other noises at the time?
Brake problem sounds like the ABS sensor problem that is caused by rust under the sensors. It causes the ABS to activate because of a weak signal from the sensor. It's not a hard fix if your mechanically inclined.
Dec 11, 2008 at 2:20 PM
TA8184
It does it all the time, louder last night, grinding noise today, now not drivable.
Thanks
Dec 12, 2008 at 3:08 AM
SWILLIAMS
  • 597 POSTS
Sounds like it's time to get it to a shop. It could be a bad front wheel hub as well. The grinding makes me think that way. Not real hard to change if you want to DIY. However from the sounds of it you need to find a shop.
Dec 12, 2008 at 5:41 AM
