2002 Chevy Blazer Out of nowere wont turn over
126,300 MILES • 6 CYL • 4WD • AUTOMATIC
RICKSTEP1982
I started and drove my blazer just fine from home to were ever and then back, with no problem. Stoped at a gasstaion filled up and when i tried to start it al I got was several clicks. I'm not sure if thats a battery, alt, starter, cylinoid problem. How can I find out my self? for some reason a jump got it running again untill i got home and now the same thing, several clicks
Aug 15, 2009 at 7:26 AM
JDL
  • 16,098 POSTS
Hello, sounds like the battery has a low charge. Some of the national brand autostores will check and charge the battery. The generic specs for a fully charged battery is 12.6 volts, using a digital multimeter-voltmeter. Also make sure the battery connections are clean and tight on all ends.
Jan 30, 2021 at 12:55 AM
