2002 Chevy Blazer need a front clip
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
WENDELLWRIGHT
can i put a 1996 front end on a 2002 chevy blazer the front fenders and the hood look the same but does it bolt up the same?
Oct 10, 2008 at 3:11 AM
SWILLIAMS
  • 597 POSTS
Yes and no. Yes it would bolt up. BUT you would need to play with the mounts some to use the 02 grill and lights. The radiator support is the part that causes the problem, depending on which headlights and options your 02 has.
Oct 13, 2008 at 10:41 AM
