2002 Chevy Blazer Fuel system
60,000 MILES • 6 CYL • 2WD • MANUAL
DROBE007
About every three or four weeks the car will not start however go back in 15 or 20 minutes and it starts fine. I have also been noticing that when I put the key in the ignition and turn, all the gages move but sometime the fuel gage does not. I have had the fuel pump replaced a couple of months ago at the dealer. If the fuel pump tests ok what other problem could I have?
Jan 19, 2008 at 9:57 PM
DENNYP
  • 1,824 POSTS
You should check all of your voltage supply circuits coming out of the ignition switch.
Jan 20, 2008 at 1:52 AM
