2002 Chevy Blazer Engine Surging At Highway Speeds
82,000 MILES • 6 CYL • 4WD • AUTOMATIC
FLASH703
My 2002 Chevy Blazer surges when it is in overdrive. It starts fine, idles fine and runs well until I get it on the highway. Once the overdrive has kicked in the engine starts to surge. The tachometer will fluctuate as much as 400 to 500 rpm's. I have taken it to a mechanic and he worked on the fuel injectors and changed some spark plug wires but this did not address the problem. I first noticed this problem after I had filled up with gasoline from a discount fillling station. I usually use Amoco, Shell or Mobil.
Mar 11, 2009 at 1:37 AM
  • 75,988 POSTS
Could be caused by the following:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Mar 11, 2009 at 1:50 AM
