2002 Chevy Blazer Dies while driving
72,000 MILES • 6 CYL • 4WD • AUTOMATIC
FIREAXE
I have not driven my blazer for sometime. The battery went dead and I replaced with a new one. While driving, it will just die, electrial will remain on but engine quits. I can restart it but a block away it will die and so on and so on.
I'm going to put on a new fuel filter. Anybody have same issue or know what to check next.
Thanks
Apr 4, 2009 at 2:50 PM
  • 110,251 POSTS
Try the filter. If that doesn't work, check fuel pump pressure to make sure it isn't low. Let me know what you find.
Apr 6, 2009 at 5:20 AM
FIREAXE
Can you tell me where the fuel filter location is on the 2002 Blazer. I bought the online repair manual as you suggested and it is not mentioned there as well as I find very difficut to use. I would not recommend it myself.
Thanks in advance for the answer.
Apr 11, 2009 at 7:19 AM
  • 110,251 POSTS
Hi:
Sorry I didn't get back sooner. I had another extended say in the hospital.
I believe the fuel filter is along the frame rail on the driver's side.
Let me know if this helps.
Apr 14, 2009 at 12:32 PM
