2002 Chevy Blazer ABS and Brake lights are both on
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
MCLANE
both the ABS and Brake lights are coming on and the anti lock brakes are engaging prematurely
Dec 5, 2009 at 4:28 AM
SWILLIAMS
  • 597 POSTS
If both lights are on I would look over the brakes for a leak. If the problem was only in the ABS system only it's light would be on.
What is the fluid level in the master cylinder? Low or empty?
Dec 5, 2009 at 1:51 PM
