both the ABS and Brake lights are coming on and the anti lock brakes are engaging prematurely
Dec 5, 2009 at 4:28 AM
SWILLIAMS
✓Experienced Mechanic
If both lights are on I would look over the brakes for a leak. If the problem was only in the ABS system only it's light would be on.
What is the fluid level in the master cylinder? Low or empty?
