2002 Chevy Blazer 2002 blazer
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
DENT99
I ahve been trouble shooting what started out as a #3 cylinder misfire only known problem everything else was fine and now have an engine that will rotate but will not crankover. I tested for spark using the #3 wire, spark OK. So I have changed the distributor and rotor cause it needed to be replaced. I have tested the coil and fuel pump relay all seem OK.
Any ideas on what the toruble might be?
Sep 16, 2008 at 11:24 AM
  • 75,988 POSTS
Check the compression and injector for no.3 cylinder. One dead cylinder will not warrant a No start-
Are you getting fuel with correct fuel pressure and injection pulses.
Sep 16, 2008 at 11:41 AM
