2002 Chevy Blazer
THESHEADOG
2002 Chevy Blazer 6 cyl Four Wheel Drive Automatic
Blazer won't fill up with gas. The gas pump keeps shuting off when I try to pump gas into it fast or slow.
Jun 19, 2010 at 7:49 AM
BLACKOP555
  • 10,386 POSTS
sounds like the tank fil line should be checked and made sure it isnt kinked. if thats not the case youll have to disconnect fuel tank vapor line from the charcoal canister and see if that frees it up. if so the vent valve may be bad or the canister. if still nothing id check the vapor line from tank to canister for restrictions or a bad vent valve on the tank
Jun 21, 2010 at 4:38 AM
