2002 Chevy Blazer
COLEZ04
2002 Chevy Blazer
My truck has not been running right for the past month. The diagnostics show nothing wrong with the engine or the trans, but the way it drives varies every day. Some days it wont want to shift into 2nd gear, others 3rd or 4th, and sometimes it drives with no problems. It stalled out last night, wouldnt start back up. I charged the battery and put fuel into the carberator, it started right up, then stalled out. Could a bad fuel pump cause the truck to drive this way?
Oct 4, 2010 at 8:07 AM
WRENCHTECH
  • 20,758 POSTS
You don't have a carburator, you have fuel injection. This is a high pressure system that is very pressure sensitive. The first thing you want to do is check the pressure using a gauge. You need a minimum of 55PSI to run.
Oct 4, 2010 at 8:20 AM
