2002 Chevy Blazer
MAGDA.S
Engine Mechanical problem
2002 Chevy Blazer Four Wheel Drive Automatic
I hope you can help. We bought a Chevy Blazer 2002 model RHD from Japan, I can see it was manufactured in USA.
VIN No: IGNDT13W72K116728
I can not find the Engine Code ID. I desperately need it for Clearance so I can get it register. Please let me know where I can find it on the engine, or let me know what is should look like..
Please help!!
Magda Swanepoel
Jan 8, 2009 at 6:46 AM
BRIAN 1
  • 1,030 POSTS
are you looking for the engine size? usually the ID is on the radiator shroud,it's on the emissions sticker.is this where the vehicle came from,YANASE AND CO. LTD.
GM PRODUCTS DIV. 6-38 SHIBAURA 1-CHOME, MINATO-KU
TOKYO , JP 105
post back with any other questions,BTW there are no outstanding recalls.
Jan 8, 2009 at 8:48 AM
MAGDA.S
Hi Brain
Thank you very much
Car Details:
2002/2001 Chevy Blazer 4.3l Automatic
I recon the vehicle is from Yanase for it have their sticker on the rear glass door.
No, not really looking for the engine size, I need the Engine ID Code so I can have it cleared for registration.
The only codes we found were:
1. 12554522 GM - Behind the fanbelt on the Block itself.
2. 70135 KRA 2131 C2 – Also behind Fanbelt looks like its been done with laser.
If you any examples/pictures of the Engine ID Code and what it should look like please let me know. westvanderhuiz@hotmail.com
Thank you for all your trouble
Jan 8, 2009 at 6:19 PM
BRIAN 1
  • 1,030 POSTS
found a little mofe info,VIN 1GNDT13W72K116728
Vehicle Component
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZZ Traceability : 0210118
Date Scanned : 08/14/2001 Time Scanned : 03.02.00 Scan Station : N/A
Component Code : CC - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1DY Traceability : 0216587
Date Scanned : 08/14/2001 Time Scanned : 13.49.00 Scan Station : N/A
Component Code : CF - SEQ NUM (FLEX) PAINT PROCESS
Source Plant : N/A
Part/Num Broadcast : 1CY Traceability : 0216557
Date Scanned : 08/17/2001 Time Scanned : 20.19.00 Scan Station : N/A
Component Code : CM - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1BY Traceability : 0214449
Date Scanned : 08/17/2001 Time Scanned : 22.49.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1AY Traceability : 0216614
Date Scanned : 08/21/2001 Time Scanned : 00.28.00 Scan Station : N/A
6 Cylinder Engine Locations
• L36 and L67 applications -- Center of the LH rocker arm or LH side of the engine in the oil pan rail area of the engine
• LX5 applications -- Front end of the LH rocker cover
• L35 and LU3 applications -- Front of the RH cylinder head or right side of the oil pan sump
• LA1 and LG8 applications -- Top of the RH rocker arm cover or front of RH oil pan rail
• L81 and LA3 applications -- On cam drive cover on the front of the engine
• LL8 applications -- Rear of rocker arm cover on the front of oil pan rail on the RH side
the 4.3 is L35/LU3.
Jan 9, 2009 at 1:41 AM
MAGDA.S
Hi Brian
Hope you can help again.
My 2001/2002 Chevrolet Blazer RHD was manufactured in the USA. Can I get a spare remote and key for the vehicle from the US? I came across this site and their remote looks the same as mine.
Will they work on my vehicle?
Thank you for all your help
Btw we finally got the enige ID
Magda
Jan 11, 2009 at 8:37 PM
BRIAN 1
  • 1,030 POSTS
the remote should work,it looks just like the factory ones.I looked up the build sheet on this truck it is equipted with keyless entry so that will make it easier.it has AU5 option which is keyless entry.if you buy a remote or remotes you need a tech 2 to programm it to the vehicle,which is a scan tool that the dealer has.you should be able to add the remote without any real trouble.
Jan 12, 2009 at 2:17 AM
