2002 Chevy Blazer
85,000 MILES • 6 CYL • 4WD • AUTOMATIC
AMERICANWATCHMEN
The truck would not restart when my wife got back into it. When you crank the engine it sounds like the engine is not getting any fuel. I checked all the fuses and found them to be ok. I do not know where the fuel pump is located do you? could it be something else? The truck has never had any problems with the engine since we bought it this is the first mechanical problem ever. Tony.
Apr 15, 2008 at 9:35 AM
ROWTIEAR
  • 91 POSTS
The fuel pump is located inside the gas tank.
If it is an original pump it is a likely culprit
Have the fuel pressure checked to see if it is within specs.
Apr 15, 2008 at 10:58 AM
